How to replace blower fan brushes.
Post by Ivanerrol » Mon 06 May, 2013 10:47 pm
W202 Blower Fan Fix
Intermittent or non operation of the HVAC blower fan in the w202 or W210 series
Is often caused by worn out fan motor brushes.
These brushes can be sourced easily on the web – particularly on U.K. ebay sites for very little monetary outlay. I sourced a set from a U.K. supplier and including post to Australia the cost was just under AU$10.00
Another fault is often the blower fan regulator. These are also easily sourced on U.K. ebay sites. Don’t bother getting a second hand module. It’s just as likely to go faulty on you in short time.
The Blower motor removal and replacement is straight foreword – unlike the previous W124 or W126 models. The fan motor is located above the front passenger kick panel.
In the case of this particular ’96 W202 C200 the blower fan would not operate at any speed using the controller switch on the console. If 12 volts was applied directly to the motor the fan did operate – but very noisily.
First step is get access to the motor.
Passenger side foot well. Under dash kick panel needs to com out.
Before getting the panel out the air inlet cover must be removed
Here’s the cover
Use a Philips head to turn the screw half a turn. Then the cover pulls out and off
The under dash panel has three Philips head screws to be removed.
The panel pulls forward and out
Next to be removed is the electrical connection from the blower fan cover
Re: How to replace blower fan brushes.
The blower fan cover has two clips that hold the front on tight – slide these towards the centre on both sides
Pull the cover downwards and forwards to get it off.
Get upside down in the foot well and look up you will see this
This is the blower fan motor and arrowed is the speed regulator.
All screws holding the fan motor and regulator in are Torx20 heads. You will need to buy a set of Torx bits and Torx sockets to work on W202 and W210 M.B.’s onwards.
Here’s an image of the fan motor in situ with the regulator removed. The regulator must be removed to enable you to get at all the screws holding the motor in place. Note that there are 4 screws only. The regulator is plugged into the fan motor with a largish plastic plug.
Regulator
Post by Ivanerrol » Mon 06 May, 2013 10:48 pm
Remove the fan motor
Look up into the chamber that the fan came from. Make sure there is no obstructions or dust – clean them out if there are any.
Here’s the assembled motor on the bench.
If you are simply replacing the motor with anew or second hand unit all you need to do now is put everything back in the order the items came out.
Post by Ivanerrol » Mon 06 May, 2013 10:49 pm
Repairing the motor – i.e. changing the motor brushes.
There are two screws on the top of the motor that must be removed. Also remove the regulator if it’s still on the motor. The lug for the regulator is keyed so that it can only go in one way.
After removing the two screws – as arrowed on the diagram, carefully slide the motor assembly away from the housing. You will be left with this.
See that beer bottle? It took me just one bottle to do this whole job. Removing, repairing and replacing.
Arrowed in the next image is the clip that holds one of the brushes in (there are two brushes) The clip just comes off with a screw driver – careful, there is a spring underneath.
Carefully pull the old brush out. Note the two clips and springs.
The brush must be dunsoldered from this point
Post by Ivanerrol » Mon 06 May, 2013 10:50 pm
Old techies will notice Ivanerrol’s folly in that he is using a boy to do a man’s job.
The soldering tool is tool small for the joint. When resoldering the new brush in there’s a good chance of getting a dry joint because not enough heat can be applied to the tag.
The Goldilocks choice.
One two small, one too big and the one in the middle just the right size for the job.
Remove the old brush lead, clean the tag up and it should look like this. Leave some old solder on the tag – this “tins” the tag.
Here’s the old removed brushes next to the new ones. No wonder they only work intermittently!
Solder the new brushes into place
Post by Ivanerrol » Mon 06 May, 2013 10:51 pm
Position the new brush into place
Replace the spring and holding clips
Your done.
Reassemble everything back in the order you took things apart.
Test in the car.
The fans in the W202’s are quite quiet. You should not hear much wind noise. You should hear no rattles or clunking.
Open another beer.
Started this job at 16:30 finished by 17:20
I have never done this job before.
Looked it up on the net didn’t find any images – so decided to do some.
Spare parts wreckers quoted near $200.00 for a an old fan blower motor. Chances are the brushes would have been required in a second hand unit anyway.
The stealership price was in excess of a Thousand bucks.
To do this job you must have some knowledge of how to solder plus the right tools and equipment. Buying a soldering iron and some solder down at the local electronics store plus buying the brushes and replacing them yourself is still far cheaper than buying a second hand motor at a wreckers.
Post by pastelgrey300D » Mon 06 May, 2013 11:30 pm
Outstanding thread! Thanks for posting, there is a possibility that we may end up with a 202 or 210 in the future so great to see threads like this. And proof that there is still plenty of the old DB engineering DNA in these cars, more modern cars would have one way tabs and catches or have everything pressed together instead of screws... :occasion5:
redlaser
Post by redlaser » Thu 09 Apr, 2015 10:24 am
I'm about to replace the blower in a W126 series 2...do u know if the procedure is the same as above?
Post by Tony From West Oz » Thu 09 Apr, 2015 11:05 am
I am sure that removal would be different but the actual brush replacement would be similar. There is likely to be a different brush retainer system too.
Soldering the new brushes in should be the same.
Why not do a tutorial on the brush replacement for W126's?
Post by Ivanerrol » Thu 09 Apr, 2015 7:26 pm
redlaser
Post by redlaser » Fri 10 Apr, 2015 9:34 am
Thanks muchly for info...I had searched for several days and did not come on the site...guess a "squeaking blower " were the key search words!
tsharkey
Post by tsharkey » Wed 29 Apr, 2015 11:12 pm
Ivanerrol wrote: Started this job at 16:30 finished by 17:20
Clearly I didn't have the performance enhancing drugs you were drinking as it took me 90 minutes ...
Great post and thankyou for going to the trouble, yet another item on the W202 fixed.
Post by Ivanerrol » Wed 29 Apr, 2015 11:45 pm
Great post and thank you for going to the trouble, yet another item on the W202 fixed.
Probably because I have all the proper tools and have been doing electronic soldering works for 45 years. :whistle:
176bob
Post by 176bob » Thu 30 Apr, 2015 12:17 pm
Absolutely spot on, great tutorial. Thank you. Bob.
piperjon
Post by piperjon » Sat 10 Dec, 2016 5:03 pm
Hello
I have been trying to find on the internet a set of brushes for my blower motor W202 C180 1997 Merc. But doesn't seam to be any good. Does any one know where I can pick up a pair??
I suppose ring Mercedes that maybe no loner made like a few thing you need.
As I asked if any person know where I can buy a pair. Please let me know.
All the best.
John
Post by Ivanerrol » Sun 11 Dec, 2016 10:24 pm
Try Ebay UK. That's where I source them.
piperjon
Post by piperjon » Fri 22 Sep, 2017 8:47 am
Hi guy's.
thanks Ivanerrol for showing use who have trouble with the blower fan as I did. Added the new brushes and now it works well. Thank you for all the pictures from start to finish.
Great stuff.
Cheers John :wav:
