Mystery colour... Help!
Twigz
Region: Western Australia
Post by Twigz » Fri 16 Mar, 2018 5:23 pm
Hi everyone, this is my first post here.
About a month ago, I bought a beautiful W126 280SE. It's only got 130,000 km on the clock and is mechanically perfect, but the paint is quite rough... Faded and peeling clear coat, and a few chips and scratches. I went to my local Auto One to get some touchup paint, but my paint code doesn't match anything in their system. I've ended up having to go to a paint store and getting them to scan the car and mix up some paint that hopefully matches, but I'd really like to know what the factory colour name is. The paint code on the plate is MA669. Googling it hasn't helped.
Just in case this helps, my car seems to be a private import from Malaysia. Not sure if that matters or not.
I really hope someone out there can help me, and I look forward to being a part of this group for many years to come!
1985 280SE - daily driver
Re: Mystery colour... Help!
Post by Ivanerrol » Fri 16 Mar, 2018 11:09 pm
Post your VIN.
Then we can help you with it.
Having said that most W126's with white paint come standard. Even released in Malaysia.
You probably have a car with no emission products - which is a good thing.
Unfortunately peeling clear coat requires a complete renewal. No patch ups will sort bit out.
Twigz
Post by Twigz » Fri 16 Mar, 2018 11:23 pm
Thanks. My VIN is WDB1260226A172820. I searched it on benzfans and it said my paint code is DB737 - Mercedes-Benz "Classic White"... which doesn't match my DARK BLUE car. The trim and cladding codes match though. But then it says it was manufactured in 2006 in Germany. I'm so confused right now.
Other than that, yep, it's got no emissions control systems, just a plain old M110.98 straight 6. I love the sound of it, I just wish it had a little bit more power.
I've been doing a cut and polish, gradually doing one panel at a time, and the results so far have been very promising. I'm hoping it doesn't require a full respray, but if it comes to that then I guess it'll have to be done.
Post by Ivanerrol » Fri 16 Mar, 2018 11:44 pm
Ident. number (FIN) WDB1260226A172820
VIN WDB1260226A172820
Baumuster 126022
Sales name 280 SE
Permanent link http://carinfo.kiev.ua/cars/vin/mercede ... zu0bhni0qf
Order number 0 5 855 11151 (Destination: Malaysia)
Delivery date 1985-06
PAINT1 737 N/A
Interior color 974
General data for model code 126022
Paint Code 737. Classic White.
This would be this :
readily available at the stealership and should be no trouble being replicated at any body works who have worked on MB's.
Post by Ivanerrol » Fri 16 Mar, 2018 11:50 pm
These cars had plenty of power at the time they were contemporary.
The transmission lets them down a little as they are designed to start in second gear for "conservative drivers" of the era.
In many parts of Asia - at the time - 1980's. vehicles were restricted to engines of 2.8 litres.
In Malaysia, an S class was a millionaires car. In Singapore a 560SEL cost a million Singapore $.
Twigz
Post by Twigz » Sat 17 Mar, 2018 12:06 am
So it is supposed to be white. I wonder when it got resprayed blue then. It's been done properly, with everything out of the car, and there isn't even a speck of white, even under rubber plugs in the engine bay. I really like the current colour, and definitely don't want to bring it back to white. I'll see if I can find a photo.
Twigz
Post by Twigz » Sat 17 Mar, 2018 12:09 am
Here we go. This is the best photo I could find of my car.
Post by Ivanerrol » Sat 17 Mar, 2018 1:53 am
Geee. :whistle:
Is the VIN stamped into the firewall? Or is it just on a removable plate?
There where some shenanigans going on between roads authority officials and some illegal importers back in the eighties and nineties. :dontknow:
According to the VIN site you should also have a Brown velour interior. If you have MB tex or leather you have some suspect vehicle.
Does the engine number match up?
Twigz
Post by Twigz » Sat 17 Mar, 2018 2:25 am
The VIN is stamped on the firewall. Not sure about the engine number, I'll have to check that in the morning. The interior is correct though (thank god, I hate old leather).
Post by KimB » Sat 17 Mar, 2018 11:32 am
Mr Twigz,
Despite all the discrepancies, that looks to be a very nice 280SE. That 2.8 motor was carried over from the previous W116 280SE model. They are sluggish on take off as Ivan said, but once up to cruising speed, they go all day.
Before I discovered the magnificent world of the W126 series, I owned a W116 280SE. Like I said, slow on take off, nice on the highway. I never had any trouble from that 2.8 motor nor from the transmission in the 10 years I owned it.
In fact, looking at your photo with the fur lined bonnet adornment.....I can hear that 2.8 PURRING from here! :dance:
Kim
