Hello all
What is the correct and best power steering pump fluid to use for the W116 280se.
Also , the filter in the pump. Mine is like a round piece of hard cork or similar.
Can this still be purchased?
Steering pump Fluid and filter for W116
- S Class
- Model you own: w116
- Region: New South Wales
Re: Steering pump Fluid and filter for W116
Mercedes as well as most all car manufactures want you to use only their SPECIAL lubricants and fluids HOWEVER for over 40 years I have used and still do in all my older Benzes 1958-1989 plain old Automatic Transmission (Dextron 1 11 or 111) with ZERO problems ever.
Your Round Cork Like filter can be back flushed with a good Cleaner like BrakeKleen or naptha and or replaced and I think they are still available .
