spark plug wires
350sl
spark plug wires
Post by 350sl » Sat 26 Aug, 2017 7:50 pm
Hi, I see some original early Mercedes r107 and earlier V8 models have yellow coloured bands attached to each plug wire near the spark plug wire holder on top of each rocker cover. Does anybody know what they are for and where you can buy them for my early Mercedesr107 350sl 1971.
Thanks, Chris
Marcel107
Re: spark plug wires
Post by Marcel107 » Sun 27 Aug, 2017 1:18 am
do you mean the cablenumbers?
Like in the picture below from my M103 in a 300 SL
Best regards from Germany
Marcel
300 SL / R107, Year 1986
300 CE-24 /C124, Year 1990
Post by AMG » Sun 27 Aug, 2017 11:05 am
Yes they have individual part numbers.
Unless you have a set of genuine leads, there is no guarantee you can fit them, as the beru leads have threaded connectors on the end of the lead, enabling the ends to be changed out, or a lead to be changed out individually.
Modern sets are not all made this way, so you need to know what you have before you waste the $ on the lead number rings
350sl
Post by 350sl » Sun 27 Aug, 2017 1:29 pm
Thanks for that, so I see quantity two for each does that mean one at the distributor and one on top of the rocker covers at the spark plug wire holder?
Chris
Post by AMG » Sun 27 Aug, 2017 5:52 pm
2 per wire.
If you can undo the resistor caps, then feed them onto the wire from that end. make sure they are on the correct wires first. (do one at a time).
They slide freely on the plug wire.
they are sold individually, not in pairs.
Post by John Green » Sun 27 Aug, 2017 6:45 pm
These are still available though us. Call to order, from memory just a few dollars each.
If you are trying to make your car original, we can also help with the 100% original metal tyre valve caps.
350sl
Post by 350sl » Sun 27 Aug, 2017 11:15 pm
Thanks for all the help, I will order them as well as the caps too! Cheers Chris
