Californian Lights and “Limp home” blocks FS
Ludwig
Post by Ludwig » Tue 12 Jun, 2018 6:41 pm
I have, today, listed a set of Californian headlights Together with an incomplete set of “Limp home” blocks of Gumtree.
If I knew how to put pics onto this system then I would do so however, I do not, and so, if you are interested then check out Gumtree under Mercedes Benz W109 W112 Rare Parts.
1954 W180
1971 W109 300SEL 3.5Litre
1981 W123 280e (2)
1982 W124 230e
Re: Californian Lights and “Limp home” blocks FS
Post by John Green » Wed 13 Jun, 2018 10:40 pm
Here you go:
https://www.gumtree.com.au/s-ad/dale/ca ... 1186762726
Do you have two of four of the front blocks? And are the lamps wired to USA or European spec?
Return to “W108/109”
