Asbestos containing materials
Posted: Sun 04 Mar, 2018 7:04 pm
by MMWA
What are the asbestos containing materials in the 109 series? in particular the 6.3
Are the engine gaskets made out of asbestos?
I have a mint pair of newly refreshed cylinder heads for the engine rebuild currently under way along with the original ones like swiss cheese and just noticed the old exhaust manifold gaskets sure as sh!t look like asbestos.
Is there anything else i should be worried about, such as cable sheathing or other insulation materials.
Re: Asbestos containing materials
Posted: Tue 06 Mar, 2018 12:55 am
by TJ 450
As discussed earlier I would say the brake pads are a good candidate even on later cars, and almost as hazardous is the fibreglass insulation lining the trans tunnel, front floor and lower firewall areas during removal.
Tim
Posted: Tue 06 Mar, 2018 10:26 am
by Mercmad
The only people who worry about asbestos in the old style head gaskets are border force. You must have a very early 6.3 if it has copper asbestos sandwich gaskets though. They normally have the elring composite gaskets . If you sniff them you might get a dose of the meso ,so just use common sense when taking them off .
Posted: Tue 06 Mar, 2018 2:47 pm
by Bartman4800
There could also be asbestos in the clutch plate, if you have a manual...
Posted: Tue 06 Mar, 2018 7:01 pm
by Aegean
and exhaust manifold gaskets.
Posted: Fri 23 Mar, 2018 3:47 pm
by merc-304
And in Maseratis / ABC news.
