4-speed manual clutch adjustment
VFRBoy
Post by VFRBoy » Tue 14 Nov, 2017 11:36 am
Is there a method to adjust the clutch? Take up is happening very close to the floor and thus not completely disengaging and shifting is difficult.
So for now I'm getting by with a bit of heel and toe on the downshift, and putting it into gear before starting the engine.
Fluid levels are good and no evidence of air in the lines. Otherwise all is well...
Appreciate any guidance!
1966 W108 250S
4-speed floorshift
Carn the Dees...
Re: 4-speed manual clutch adjustment
Post by Bartman4800 » Tue 14 Nov, 2017 12:27 pm
It is a hydraulically operated clutch.
The only thing to adjust is the extension rod on the slave (mounted on the gearbox).
Undo the nut and extend the plunger. Make sure there is 1-2 mm of free play otherwise your throw out bearing will wear very quickly.
Lance
Post by Lance » Tue 14 Nov, 2017 4:55 pm
On the W114 manual the bolt that connects the actuation rod to the pedal is eccentric. If there is free play as you depresss the pedal then loosen rotate and tighten.
Lance Smart
W114 280E 5 speed manual
W123 280E
Post by Mercmad » Wed 15 Nov, 2017 5:20 pm
Sounds like the clutch is worn out . you measure the wear by the amount of rod protruding from the slave cylinder . Theres a guage that you place against the rod to determine the wear .
VFRBoy
Post by VFRBoy » Thu 16 Nov, 2017 9:34 am
Thanks for the tips guys - on it!
Is this achievable with a trolley jack and axle stands or is a hoist necessary?
1966 W108 250S
4-speed floorshift
Carn the Dees...
Post by Bartman4800 » Thu 16 Nov, 2017 10:28 am
To adjust the rod (or measure as Ron said), you need to jack up the car high enough so you can slide underneath.
I put my jack stands on 100 mm timber blocks.
Jack stands are certainly the go, but a hoist is always easier...
VFRBoy
Post by VFRBoy » Mon 20 Nov, 2017 9:43 am
OK the lock nut on the clutch throw rod had come loose.
That's fixed, but now waiting on a seal kit for the master cylinder as it's not pumping enough.
1966 W108 250S
4-speed floorshift
Carn the Dees...
Return to “W108/109”
