Bushing Size - Lateral Subframe Support
hendriknz
Post by hendriknz » Thu 24 Aug, 2017 9:49 am
Hi all,
I have need to install a replacement lateral subframe support rod in my W108 280se 3.5 and have sourced a second hand one.
The bushings are a bit worn though. Does anyone know what i the correct sized bushings and a link or part number to obtain the same.
cheers
W108 280se 3.5
New Zealand
Re: Bushing Size - Lateral Subframe Support
Post by Bartman4800 » Thu 24 Aug, 2017 8:01 pm
Call MBspares, they sent me one for my W111 instantly.
Hole size could be larger, otherwise I suspect it is very much the same.
Post by John Green » Fri 25 Aug, 2017 1:39 pm
We have them in stock and ship to NZ. Things are a little slow there as I are off recovering from prostrate surgery, but if you make contact we can supply them.
ibast
Post by ibast » Sat 02 Sep, 2017 9:14 am
I got mine through MB spares. They weren't that dear.
Return to “W108/109”
