Tri-y's for my 420SEL
420.SELect
Post by 420.SELect » Fri 16 Feb, 2018 5:48 pm
Hi all,
I have very luckily found a pair of RHD tri-y's and would just like to get confirmation from the group that these are indeed the real deal.
I did obviously go through a number of posts from multiple forums to compare and they do look the goods but I would like to get your opinions before I dump 700+ on them.
Thanks!
Chris
1988 420SEL - Agnes
hents99
Re: Tri-y's for my 420SEL
Post by hents99 » Sat 17 Feb, 2018 12:00 am
Check part numbers...I believe they are for M117.
M116 and M117 ports are different.
420.SELect
Post by 420.SELect » Sat 17 Feb, 2018 6:26 am
Thanks for your reply, Hents.
After I did not receive any replies - especially given the subject of tri-ys - I started doing a bit more research. This led me to believe that tri-ys were only on euro 560s and that the manifolds are not interchangeable. Devostated!
I was so excited to find tri-ys that It didn’t even register that all the stuff I have read has been for 560SEC/SELs.
Guess I just have be thankful that I have found a well maintained W126 and stop trying to make it something it’s not.
Sorry for wasting your time.
1988 420SEL - Agnes
420.SELect
Post by 420.SELect » Sat 17 Feb, 2018 6:57 am
If anybody is keen to have a look, I have put the link below.
https://www.gumtree.com.au/s-ad/bowral/ ... 1156684086
Hopefully a fellow Ozbenzer can make good use of them!
Chris
1988 420SEL - Agnes
Post by CraigB » Sat 17 Feb, 2018 7:23 pm
Just for the record - what is the difference between m116 and M117 manifolds? if bolt pattern the same can ports be modified to fit?
Post by T-Modell » Sat 17 Feb, 2018 8:04 pm
afaik the bolt pattern is identical. When I did the manifolds for my M117, the reference block was a M116. Block measurements were different, but the "exits" were the same.
hents99
Post by hents99 » Sun 18 Feb, 2018 8:22 pm
M116 and M117 manifolds bolt pattern is same and you can swap them.
I found some pics of drawings...
M116 flange (port and bolt holes has same centerline)
M117 flange
420.SELect
Post by 420.SELect » Sun 18 Feb, 2018 8:39 pm
So you’re saying that I am able to put these on the 420?
1988 420SEL - Agnes
hents99
Post by hents99 » Mon 19 Feb, 2018 9:11 am
Yes. But ports are not aligned. Difference is about 3-4 millimeters...I must check cad drawings.
Little bit port matching and should be OK.
420.SELect
Post by 420.SELect » Mon 19 Feb, 2018 3:30 pm
Thanks for the update, Hents.
The guy I bought them off did an engine swap, 500SEL into a 380SL, and reckons that the lengths of the cylinder heads and stud configuration is identical; as he used the M116 manifolds on the M117 without any issue.
Not sure why, I surely wouldn't, but that is what he said.
I don't really feel like performing any port matching.
Chris
1988 420SEL - Agnes
Post by CraigB » Mon 19 Feb, 2018 4:01 pm
In the smaller W107 sl engine area not enough room for the tri-ys - that's why he used them. Port matching you can put your gasket over the manifold lined up as a guide. You would think the manifolds would be bigger diameter if anything though - may not need much.
420.SELect
Post by 420.SELect » Mon 19 Feb, 2018 5:42 pm
Ahhh, that seems logical.
Yeah, I would assume the same. Not nearly as detrimental if the manifold is larger; just way more of a pain to port the heads than the manifold.
Chris
1988 420SEL - Agnes
